1. KinDranex's Avatar
    For a couple of months now I get this weird overlay of other apps on my screen. It happens consistently and the app that's overlaying is one I just used, I've restarted my phone multiple times, the overlay doesn't appear on screenshots
    12-07-2017 07:11 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Can you show us a screenshot? http://forums.androidcentral.com/gen...d-central.html
    12-07-2017 12:53 PM
  3. KinDranex's Avatar
    Moto G4
    12-07-2017 03:22 PM
  4. B. Diddy's Avatar
    Derp, I don't know how I missed that in your OP -- sorry!
    Instead, can you take a picture of the screen with another device and post that? The actual image might jog the memory of other members, if they've experienced the same thing.
    You might also want to see if any currently installed apps have a screen overlay, and turn it off temporarily: https://www.howtogeek.com/271519/how...or-on-android/
    12-07-2017 05:55 PM
  5. KinDranex's Avatar
    none of my apps have a screen overlay.
    I don't have another device to take the shot
    12-07-2017 06:36 PM
  6. Javier P's Avatar
    Welcome to the forums. The overlay you get, is it always like a shadow of the previous app you used? If so, that sounds like screen retention. I remember reading similar reports with the G4. How high is your brightness level (settings - display)?
    B. Diddy likes this.
    12-07-2017 06:52 PM
  7. KinDranex's Avatar
    It's a shadow of a previous app I used
    Attached Thumbnails Need help with this weird blue overlay bug-screenshot_20171208-013655.jpg
    12-07-2017 07:43 PM
  8. Javier P's Avatar
    Yeah, it sounds like a bad case of screen retention. Most likely the only real fix could be replacing the screen, but just in case you can try a couple of things. Set the brightness a bit lower (less than 50%) and make sure that 'adaptive brightness' is enabled. Also, see if the solutions included here work for you.
    https://forums.lenovo.com/t5/forums/...id/6142/page/1
    12-08-2017 06:58 AM
  1. Replies: 6
    Last Post: 01-03-2018, 06:56 AM
  2. Replies: 1
    Last Post: 12-20-2017, 12:44 PM
  3. Sharing what I'm seeing on my VR with others.
    Last Post: 12-07-2017, 01:39 PM
  4. What are some good self help games for Android?
    By andarras1983 in forum Android Apps
    Last Post: 12-07-2017, 04:53 AM
  5. so how can i fix this problem?i mean beta programme?
    Last Post: 12-07-2017, 04:18 AM
