1. Admdata13's Avatar
    Hello all,
    I have a 7 inch android tablet running kitkat version 4.4.3 (not 100% sure if it is 4.4.3 or 4.4.4) anyhow it is a intel atom based system, my wife when to shut the tablet off a few days ago and she got a wierd screen when she went to turn if off, so she thought the battery was dead and plugged it in. Anyhow I get home (hours later), and goto turn on the tablet I get the bootloader screen and then I get a usb symbol and then the tablet turns off, each time I hit the power button (BTW: the device is not rooted and is using the stock rom that the device shipped with), I have gone into the recovery menu and did a wipe data/factory reset on the device a few times, then after I hit the reboot system now option with no luck still get the usb symbol and the tablet turns off.
    Any help would be great ie is the tablet toast or is there a way to turn off usb mode and go back into the normal boot cycle.
    Also the bootloader is locked as well.
    12-07-2017 09:24 AM
  2. Rukbat's Avatar
    It sounds as if you have to reflash the firmware, but without knowing the manufacturer, no one can guess how to do that for you. Post the make of the tables and, if it's a common one, someone can tell you where to get the firmware and how to flash it. (If it's one of those cheap Chinese tablets, that may not be possible. Cheap Chinese tablets are actually quite expensive, since you have to keep replacing them.)
    B. Diddy likes this.
    12-07-2017 12:01 PM
  3. B. Diddy's Avatar
    An excellent point.
    12-07-2017 12:14 PM
  4. Rukbat's Avatar
    Just pointing out what we see here every week.
    12-07-2017 12:16 PM
  1. Can't edit calendar entries from Office 365 (web browser) with my new phone!
    Last Post: 12-07-2017, 03:29 PM
  2. Oreo or Nougat on the Honor V10?
    By Android Central Question in forum Honor V10
    Last Post: 12-07-2017, 02:06 PM
  3. Danish language on a Xiaomi MI6
    By FlyUnited in forum Ask a Question
    Last Post: 12-07-2017, 09:06 AM
  4. Why is my s7 automatically muting.
    Last Post: 12-07-2017, 08:39 AM
