1. usinnit's Avatar
    I've been looking for an android compatible dvd writer but there doesn't seem to be one that I can find.
    I've seen a couple of tuts using MLUSB Manager and External DVD Drive OTG Player from the Play Store using an OTG USB adapter but they seem to be hit and miss.
    Is there an actual DVD writer that's more or less plug n play?
    This is the tablet bought: https://www.amazon.co.uk/Expandable-...cUvbUpU6104553
    This is the dvd writer she bought with it, which actually says "frequently bought together", but there's also a windows version of the tablet so I'm assuming that they've mixed it up with that.
    https://www.amazon.co.uk/Blingco-Ext...cUvbUpU6104553
    Cheers for any help guys.
    12-12-2017 08:11 AM
  1. Titles of notifications tiny in android 8.1?
    Last Post: 12-17-2017, 08:52 PM
  2. Note 8 Outlook for Android Quirky Behavior
    Last Post: 12-12-2017, 07:40 AM
  3. Replies: 0
    Last Post: 12-12-2017, 01:30 AM
  4. How to remove e-mail autofill from Alcatel Pixi Cellphone Android 6.0
    Last Post: 12-12-2017, 12:49 AM
  5. Replies: 0
    Last Post: 12-12-2017, 12:24 AM
