1. Kelemvor33's Avatar
    Howdy,
    I have an LG G3 that I want to hard reset. I need to backup the data so I figured I'd use Helium.
    I'm using the Free version so the data backs up to a local folder on my phone. Since I'm going to reset the phone, how do I save the data and then put it back? Do I just go into the folder on the phone and manually copy the file(s) over to my computer and then copy them back over after and rerun the app? Will it just read in the file and let me restore everything?
    Just don't want to wipe the phone and then find out something went wrong.
    Thanks!
    12-17-2017 07:42 PM
  1. A better backup program
    By Ansovald in forum LG G6
    Last Post: 12-23-2017, 06:20 PM
  2. Connection time out on vivo x3t phone using Wi-Fi network
    Last Post: 12-18-2017, 12:07 PM
  3. Enter backup password won't take
    Last Post: 12-18-2017, 12:04 PM
  4. Why is my phone speaking out loud every app/thing I touch.
    Last Post: 12-17-2017, 07:20 PM
  5. Replies: 1
    Last Post: 12-17-2017, 06:06 PM
