1. bucknell's Avatar
    Setup: Google Pixel 2, Android 8.1.0
    App: default Android Message app
    How can I add a custom .mp3 and assign it under Settings/Notification/Sound/ in the Message app?
    I have loaded .mp3 files in /Ringtones as well as /Notifications, I can only see my custom .mp3 files added to the default list while assigning Ringtones, but not in Message app.
    12-18-2017 10:15 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Moved from the Android Apps forum to the General Help forum, since the former is intended for developers to promote their apps.
    It should work. Where is the mp3 file from? There's no DRM protection on it, right?
    Is it the same mp3 file in both the /Ringtones and /Notifications directory, or are you talking about different sound files?
    12-18-2017 11:37 AM
  3. bucknell's Avatar
    I created the mp3 file using an mp3 app to clip a tone for text messages, it worked fine on my iOS. I downloaded and copied the same file into both folders. I can see it when assigning ringtone to the phone, but not in Android sms Message app.
    12-18-2017 12:42 PM
  4. B. Diddy's Avatar
    That's odd. Try renaming the file in the /Notifications directory to something else, in case there's some kind of conflict caused by the same file in two different directories.
    12-18-2017 08:32 PM
  5. bucknell's Avatar
    Mr. B. Diddy - aka wizard. That did the trick, thanks so much.
    B. Diddy likes this.
    12-19-2017 09:06 AM
  1. S7 running Android 7.0 Dropping Wireless Connection
    By celtek in forum Samsung Galaxy S7
    Last Post: 02-20-2018, 07:32 AM
  2. how to customize the 'mini' control center on G5S Plus?
    By gameson in forum Moto G5S & G5S Plus
    Last Post: 12-18-2017, 02:34 PM
  3. Why is my Play Store icon gone on my Android
    Last Post: 12-18-2017, 09:47 AM
  4. Android TV Box
    By nappiboy360 in forum Ask a Question
    Last Post: 12-18-2017, 09:09 AM
