1. macroman64's Avatar
    Hey everyone I'm using lineage OS, but the battery life is really average at best. I realize that this phone battery is quite old, but there are some roms I've tried like paranoid Android that gave Rock solid battery life. However that rom wasn't stable , I had no signal and apps were crashing left and right. Can you suggest awesome battery life friendly custom ROMs that are stable as well. Thanks.
    12-25-2017 06:33 AM
  1. i m facing battery drain due to media and media server
    Last Post: 12-25-2017, 01:17 PM
  2. Replies: 2
    Last Post: 12-25-2017, 01:13 PM
  3. Is it absolutely necessary to remove the case when wire charging the Galaxy Note 8?
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 12-25-2017, 11:33 AM
  4. My LG P930 doesn't have the Play Store
    Last Post: 12-25-2017, 11:30 AM
  5. Replies: 0
    Last Post: 12-25-2017, 05:34 AM
