1. dlalonde's Avatar
    Every year I change all my passwords on my important accounts. It may sound overkill but I'm a computer tech so I tend to be more careful that the average user ;-)
    That being said two years ago I also reset my phone which triggered the device protection. So I was barred from my phone for 2 days.
    So I was wondering how long should I wait before resetting my phone after changing my password? I know the lockdown has been changed to 24 hours but does that also mean I should wait 24 hours after changing my password before resetting or is it just the lockdown time?
    12-31-2017 10:04 AM
  2. Rukbat's Avatar
    Yes. (And, as you know, some sites make you wait longer. Google is being nice by shortening it to 24 hours.)
    12-31-2017 12:10 PM
  3. dlalonde's Avatar
    Yeah I know but the phone is a bit more 'dramatic' so to speak. :P
    So just to make sure I understand your answer if I change my password now, tomorrow at the same time I can reset my phone and should not have any issue. Correct?
    12-31-2017 01:14 PM
  4. Rukbat's Avatar
    It's a bit late now, but yes, you should be able to use the new password now.
    dlalonde likes this.
    01-01-2018 03:43 PM
  1. Replies: 6
    Last Post: 01-01-2018, 01:19 PM
  2. Note 5 locked to Rogers but Rogers cannot find my IMEI
    By DevilsSonInLaw in forum Ask a Question
    Last Post: 12-31-2017, 12:28 PM
  3. Is it safe to use the blackweb slim portable battery to charge my Droid Turbo 2
    Last Post: 12-31-2017, 11:57 AM
  4. How to vote on Varsuz
    By ivanmingo in forum Android Apps
    Last Post: 12-31-2017, 09:22 AM
  5. Why do my apps disappear randomly!
    By Annoyed2323 in forum Ask a Question
    Last Post: 12-31-2017, 08:55 AM
