1. Postoid's Avatar
    This evening tap settings and at the very top I see a "suggestions" bar. It says enable double tap power button to launch camera. Ok, I'll try it and if I don't like it, I should be able to turn it off. I'm on 8.1.0 Nexus 6P.
    Checked the net for "turn off double tap power button to launch camera" Went to "settings" > display > and nothing there on my display screen showing you that it can be disabled. I'm stumped. Help.
    01-03-2018 08:53 PM
  2. Postoid's Avatar
    Ha..found the answer. In the search bar at the top of the phone I typed 'Jump' and this came up :
    Jump to camera
    To quickly open camera, press the power button twice. Works from any screen.
    System>Gestures> Jump to camera.
    Hope this helps someone
    01-03-2018 09:21 PM
  3. AndyOrmsby's Avatar
    Thanks. I've been looking for a solution to this for ages.
    10-09-2018 02:39 AM
  4. Alborandres's Avatar
    Jump to camera
    Thanks bro! It was making me mad.
    01-28-2019 12:45 PM
  5. stefanostambazzi's Avatar
    Thanks so much! I've been looking everywhere for this setting (well apparently except for there!)
    04-02-2021 03:12 AM
  6. mustang7757's Avatar
    Hi, welcome to AC!
    Glad you found this thread useful
    04-02-2021 10:38 AM
  1. Why is there a privacy leakage sign when taking a picture on messenger
    Last Post: 02-22-2018, 04:26 AM
  2. Turn OFF wifi
    By 103Softail in forum Samsung Galaxy Note 8
    Last Post: 01-04-2018, 04:09 PM
  3. Why does my galaxy s8 hang up when i bring it up to my ear?
    Last Post: 01-03-2018, 10:51 PM
  4. volume buttons and active button won't work
    By slickxsparkie in forum Samsung Galaxy S7 Active
    Last Post: 01-03-2018, 08:44 PM
  5. my phone always show a process tag, how to eliminate it?
