Can I update the Firmware to new firmware if the box stopped powering up the light shows it just stopped powering. the seller said it needs a firmware update.
Is this possible?
Is this possible?
I have read elsewhere it can be done. a power light is on but nothing comes on screen.
Okay, so you called it an "Android box" - what does that mean? Are we talking about a phone? A tablet?
What manufacturer? What model?
And - as an aside - if fixing it is so simple, why doesn't the current owner fix it and *then* sell it for, presumably, a substantially higher amount?
Android boxes usually refer to tv set top boxes/media players
