1. Natalie Zyra Reyes's Avatar
    I've been using my earphones for months and it was perfectly compatible with my device, even though i bought it from a store it works well with my phone even the microphone works. But then this morning i was using my earphones bcause i was watching a movie, i installed an app and then when i exit the app my earphones were magically not working even though it was connected, i did a research on youtube, i cleaned the jack but nothing happened, i tried my earphones on another device but it perfectly worked! Can someone please help mem? I really dont have the money to buy a new one...
    pugislife likes this.
    01-06-2018 12:33 AM
  2. Rukbat's Avatar
    Try uninstalling the app you installed just before they stopped working.
    Natalie Zyra Reyes likes this.
    01-06-2018 01:19 PM
  3. Natalie Zyra Reyes's Avatar
    I tried it and it still wont work
    02-03-2018 08:31 PM
  4. pugislife's Avatar
    Having the exact same problem on my p10 lite from huawei. Using a pair of skullcandy-s trrs.
    Suddenly stopped working in a morning.
    NOTICE: Every other headphones work( trs/trrs), and the problematic pair of headphones work on any other device. This must be a software issue idk.
    hope this gets fixed (((
    03-13-2018 02:57 PM
  5. icedlemontea19's Avatar
    (I already posted this reply on another thread but I'm afraid that you guys won't find it so :P)
    Hey there!
    So recently my tablet had the same problem. I was listening to Spotify overnight and the next morning I realized my headphones stopped working. But the weird thing was that the headphones still works well with my phone. I checked the jack to see if lint was in it and I cleaned it with cotton but it still won't do.
    I searched up apps that would help fix my tablet and I found one that works like charm: https://play.google.com/store/apps/d...forandroid2016
    All I had to do was click on "Deep Scan" let it scan for like a few mins and voilà! Plugged in my beloved JBL headphones and now I can listen to Metallica and NF screaming at me at 4 a.m without waking up my sister.
    Hope this helps!
    07-18-2018 09:26 AM
  6. amhu's Avatar
    Same problem with my Mate10, I think that happened after my last update.
    08-03-2018 01:50 PM
  1. Data connection suddenly stopped working.
    By KrisYYC in forum Samsung Galaxy Note 8
    Last Post: 01-06-2018, 11:00 AM
  2. Replies: 1
    Last Post: 01-06-2018, 06:00 AM
  3. what happens if Iforgot knock code on lg g3?
    Last Post: 01-06-2018, 01:03 AM
  4. How to I use text to speech on Kindle in android other than talk back
    Last Post: 01-06-2018, 12:24 AM
  5. Q Fonder 2.0 not connecting to Pixel 2 in Android Wear
    Last Post: 01-05-2018, 11:13 PM
