1. L n a 12's Avatar
    Hi I would like to ask if anyone knows why I just got an sd card for my lg android and I started out moving apps just fine but after the first app I can no longer move apps to my sd card
    01-09-2018 07:19 PM
  2. STARGATE's Avatar
    Hello and welcome to the forums at Android Central!
    The latest Android OS doesn't permit moving entire apps to SD cards. So that might be the cause of your problem.
    Try using the SD card only for pictures, videos and documents if you're interested on gaining more space on your phone's internal storage.
    Sent From Inside the TARDIS with my Note 8
    01-09-2018 08:05 PM
  3. Golfdriver97's Avatar
    Welcome to the forums!
    01-10-2018 09:07 AM
  4. belodion's Avatar
    Welcome aboard!
    01-10-2018 09:20 AM
  5. Javier P's Avatar
    Welcome to the forums. I agree with STARGATE, better if you use the card only for documents and media files. Some models let you format the card as internal/adoptable storage, but I consider this feature a bit risky and buggy.
    01-10-2018 09:55 AM
  6. Morty2264's Avatar
    Welcome to the forums! Hope you enjoy your LG phone and that things get resolved for you!
    01-10-2018 09:57 AM
  7. Almeuit's Avatar
    01-10-2018 12:30 PM
  8. B. Diddy's Avatar
    Welcome to Android Central! I hope you don't mind, but I moved this thread from the Introductions forum to the General Help forum, since your original post is primarily a question. You're less likely to get an answer to your question in the Intros, since people go there primarily to welcome the new members.
    Which LG phone do you have? Are you moving apps by going to Settings>Apps, selecting an app, and tapping Move to SD? When you say you can no longer move apps to SD, do you mean that the button no longer shows up in the Settings>Apps menu? Or do you get an error message when trying to move an app?
    01-10-2018 02:27 PM
  1. Help. I can't scroll up or down on my phone!!!
    By Tegar Sitompul in forum Ask a Question
    Last Post: 01-10-2018, 07:55 PM
  2. G3 who call I call for help sprint could not help
    By Android Central Question in forum LG G3
    Last Post: 01-10-2018, 01:25 AM
  3. need help identifying app
    By Rozik1 in forum Ask a Question
    Last Post: 01-09-2018, 06:34 PM
  4. i have a LGtablet and i would to know what i have to do to text someone
    Last Post: 01-09-2018, 06:27 PM
  5. G3 who call I call for help sprint could not help
    Last Post: 01-09-2018, 05:35 PM
