1. Dragos Bors's Avatar
    Hello I have a huawei y6 II compact and i can't connect to pc
    i run window 10 pro 64 bit
    when i connect my phone to pc Hisuite ask me to allow the pc on my phone but i don't get any notifications on my phone
    what i can do??
    Esmaeal9511 likes this.
    01-15-2018 12:40 PM
  2. Rukbat's Avatar
    I assume you said Yes?
    The download suite installs the driver, so the only things left are a bad port (in the phone or in the PC) or a bad cable.
    01-15-2018 03:50 PM
  3. Golfdriver97's Avatar
    If you are running 6.0 or higher you should have a notification for charging. If you do, tap on it and change it to file transfer.
    01-15-2018 03:52 PM
  4. Esmaeal9511's Avatar
    i have the same problem with y6 ii yesterday i tried everything >> it just doesnot work \\\\>> did u fix the problem bro, please tell me
    08-19-2018 03:10 AM
  1. Why isn't Google Play Store Working?
    Last Post: 01-15-2018, 07:21 PM
  2. Replies: 1
    Last Post: 01-15-2018, 07:19 PM
  3. Add people to text on group text
    Last Post: 01-15-2018, 03:55 PM
  4. Why i cant download music
    Last Post: 01-15-2018, 12:22 PM
  5. How many free minutes are left on my phone
    Last Post: 01-15-2018, 12:16 PM
