1. baylinv's Avatar
    LG X Charge Comcast M327
    Does anyone know how to connect this phone to the computer and use the phone FROM THE LAPTOP? For example, the Samsung S5 phones used SideSync and you could control your phone via wifi or with the usb cord. I have already tried using the LG Bridge, does nothing other than allows you to update the phones software. The LG PC Suite does not connect to the phone (I think it is because this program was for older phones).
    Please let me know if anyone knows of a way. I hope LG has a program to allow us to use this phone from the pc (laptop). Thanks in advance!
    01-16-2018 02:44 PM
  2. SpookDroid's Avatar
    You're gonna need a VNC app for that. Quite a few options in the Play Store. You install the app on your phone, the program in your computer, and connect. Just like SideSync but only to share/control the phone.
    baylinv likes this.
    01-16-2018 02:46 PM
  3. baylinv's Avatar
    I checked out that app you mentioned. I just want to be able to send text from my laptop (compose suing my laptop then send from my phone all the while using my laptop).
    Thanks. Sorry for any confusion.
    01-16-2018 05:45 PM
  4. SpookDroid's Avatar
    Ah, for texting I'd recommend MightyText, but you also have other options like PushBullet and many other texting apps. But I think you'll like MT
    Laura Knotek and baylinv like this.
    01-16-2018 11:22 PM
  1. Replies: 1
    Last Post: 01-20-2018, 02:14 AM
  2. Replies: 1
    Last Post: 01-16-2018, 02:25 PM
  3. Why can't I open a htc file on my htc phone from my restore file
    By Melinda Everhart in forum Ask a Question
    Last Post: 01-16-2018, 02:02 PM
  4. Can’t reload deleted messenger on iPhone6
    Last Post: 01-16-2018, 01:55 PM
  5. Why can't I find Instagram and Hootsuite apps on my phone?
    Last Post: 01-16-2018, 01:23 PM
