1. cuemaker's Avatar
    When using my mavic drone with s2 tablet plugged into controller it trys to charge using controller battery. someone said I could turn it off under settings, device maintenance. advance settings, fast cable charging. not there. where can I turn off fast charging???
    01-19-2018 02:18 PM
  2. SpookDroid's Avatar
    You might have to enable Developer Options, but you should be able to set up USB mode there (on the Tab S3 it's under USB Configuration). I remember you have the option to choose Media Transfer or Charging when you plug in data USB sometimes, but not sure if you can manually access that pop-up without the developer options active.
    Tim1954 likes this.
    01-19-2018 04:17 PM
  1. How to control my Galaxy S7 from my laptop with broken screen?
    By Jonathan Adames in forum Ask a Question
    Last Post: 01-20-2018, 11:35 AM
  2. why can I see someone else files(pictures, videos, etc) when I add new profile?
    Last Post: 01-19-2018, 07:43 PM
  3. HTC10- AT&T - How to show number when calling and Advanced Messaging enable
    Last Post: 01-19-2018, 12:11 PM
  4. Replies: 0
    Last Post: 01-19-2018, 11:47 AM
  5. My Samsung Galaxy Tablet 7 Won't Turn On
    Last Post: 01-19-2018, 11:36 AM
