1. KIrk Fleming's Avatar
    I just got a BlackView BV9000 Pro in the mail. I stuck my SIM card in it and its being read, I can see my contacts and phone number from it. But its not able to log into my network for whatever reason.
    I took it to the ATT store to have them verify I had the correct APN and they made a new SIM for me, but it still didn't work for them either.
    I've also noticed the boot up screen shows on boot, then waits for me to unlock it, then in splashes again before waiting me to unlock it a second time before it goes to the home-screen. This gives me the idea that the phone might be DOA or the ROM might be corrupted.
    I have reached out to the manufacturer, but while I'm waiting I figured I'd ask for some opinions here also
    01-23-2018 11:19 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I don't think that phone supports AT&T's network. It has no overlap at all with the 4G bands, and for 3G, there's only band 2 support, and it's possible that band 2 isn't strong or available in your area. AT&T shut down their 2G network, so that doesn't help.
    Blackview BV9000 Pro Specifications, Price Compare, Features, Review
    https://www.frequencycheck.com/carri...-united-states
    https://forums.androidcentral.com/e?...token=3_TfXKJN
    01-23-2018 04:38 PM
  3. shamita khanna's Avatar
    Of course, Blackview BV9000 Pro also has strong features like 128GB ROM,
    13MP camera, which I think are the reason of being so expensive. But as
    far as I’m concerned, 128GB ROM is unnecessary in terms of outdoor use.
    In conclusion, NOMU T18 is more useful and cost-effective. For people
    are more concerned with functionality and originality, NOMU T18 is a
    better choice.
    02-03-2018 03:43 AM
  1. How to unlock my Samsung galaxy tab 4
    Last Post: 07-09-2018, 05:59 AM
  2. I can't log on to an app. msg says untrusted certificate authority
    Last Post: 01-23-2018, 11:53 AM
  3. Replies: 1
    Last Post: 01-23-2018, 11:16 AM
  4. How to remove old Google page
    Last Post: 01-23-2018, 10:16 AM
  5. Google assistant defaults to speaker phone.
    By James E1 in forum Android 8.0 Oreo
    Last Post: 01-23-2018, 09:46 AM
