1. SykoTinks's Avatar
    Rooted Samsung Galaxy Grand Prime SMS920L
    01-25-2018 05:54 PM
  2. SpookDroid's Avatar
    Not sure if rooted devices can be updated via OTA through the Update option in your Settings, but that's one way IF the update is available for your specific model and region.
    Another way is to download Smart Switch to your computer, connect your device via USB, and have it check for available updates. Again, not sure if updating voids root, so if that works, you might need to re-root your device.
    01-25-2018 06:13 PM
  1. Only option to get rid of my password is to clear all credentials
    Last Post: 01-25-2018, 10:56 PM
  2. Samsung Galaxy A5 2017 automatic shutting off and restarting?
    Last Post: 01-25-2018, 07:41 PM
  3. Phone shut down and won't start back up,
    Last Post: 01-25-2018, 07:38 PM
  4. How can I change my min number?
    Last Post: 01-25-2018, 05:09 PM
  5. Replies: 1
    Last Post: 01-25-2018, 04:52 PM
