my blackview BV2000s enable to connect serve after reset...
elpiece_93
It said....
This could be a temporary problem or your Android device may not be provisioned for data services. If it continues, call customer care.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,737
113
Welcome to Android Central! Which carrier are you using? Were you making calls and connecting to the web normally before, and this suddenly happened? Or have you been seeing this ever since inserting the SIM card?
Sleezzyy21
