1. mylk100's Avatar
    I was wondering how to have links always open in Internet browser and not in some hyper link. I was able to find the setting in the email but sometimes while on the internet with my note 4 android 6.0.1 hyper links keep opening. I know it's possible and I found an answer when I owned an s5 but I can't seem to find it anymore. Any ideas would be amazing. Thx
    01-27-2018 04:37 PM
  2. B. Diddy's Avatar
    When you say "hyperlink," do you mean that the link is opening within the app? Certain apps can open links within the app itself (using a very basic browser). When this happens, look in the app's settings and see if there's an option for "Open Link In App," and turn that off.
    01-28-2018 12:17 AM
  1. Replies: 2
    Last Post: 02-05-2018, 03:45 AM
  2. How to use your phone that has been reset for Wi-Fi use?
    Last Post: 01-28-2018, 03:26 PM
  3. Replies: 1
    Last Post: 01-28-2018, 03:19 PM
  4. Replies: 1
    Last Post: 01-28-2018, 12:23 AM
  5. Samsung S7 edge crack itself??
    Last Post: 01-27-2018, 07:12 PM
