Running Android messages in Chrome?
kramer5150
1,426
Curious... is there some way to access Android messages from within Chrome? More specifically a macbook or Windows 10 computer running Chrome? They do it with google mail, why not with Android messages?
Is there something hard coded in the varying OS'es that dis-allows this?
hallux
Q&A Team
Jul 7, 2013
12,322
7
38
Android Messages are your text messages, they are not routed through Google. You'd have to check with your carrier or your device manufacturer to see if there is some kind of sync or something like that to allow you to access your texts from a device other than your phone.
rabruslik
