1. AlgodePrivacida's Avatar
    HELP!!
    I have a directory full of files... more that 1,5Gb of files... filling my /data/ partition...
    /data/data/com.kingouser.com/files/activesu/
    I know this problem ... I know this error... that directory fill up with useless files of just a couple of Kb each one... i erase that directory before make a nandroid... but this time.. things get out of hands ...
    Total Commander can not remove it... "out of memory"....
    the list of files inside is huge... ES FILE EXPLORER .. same thing it fail to....
    so i try with rm command in a terminal emulator.... but no luck...
    rm -Rf /data/data/com.kingouser.com/files/activesu/
    no such file or firectory
    rm -Rf /data/data/com.kingouser.com/files/active/*
    argument list too long
    mv command ... same thing....
    any ideas..???
    01-30-2018 04:58 PM
  2. Rukbat's Avatar
    Since the Kingouser files are just junk left from rooting the phone, how about
    cd /data/data
    rm -r com.kingouser.com
    The only file you really care about is su, which should be in /system/xbin, so it won't be affected. If you find that Kingroot's Superuser is missing after the rm, you can install SuperSU (the combination I happen to be running) with no problem. (It may ask you to update the binary - let it, and use the normal method.)
    Oh, the reason it didn't find the directory?
    The first command should have been su. /data is read-only to an unrooted user, and /data/data isn't even readable.
    01-31-2018 01:14 PM
  1. How can i get rid of my password?
    Last Post: 01-30-2018, 06:29 PM
  2. android and pc endoscope with samsung s6
    Last Post: 01-30-2018, 02:48 PM
  3. How to get dutch on my keyboard and the layout back to how it used to be.
    Last Post: 01-30-2018, 02:37 PM
  4. Video from Huawei P10 to MacBook Pro causing audio to be out of sync.
    Last Post: 01-30-2018, 01:54 PM
