Hey guys, I've been having a problem with my HTC Desire memory and was wondering if there are any suggestions out there for me. My Desire is with U.S. Cellular and is non-rooted. I only have about 10 applications downloaded in all. I'm not sure how much stock memory is on the Desire, but currently, I'm hovering around th 15MB range. I keep getting the little annoying "Low Memory" notification, so I always have to go in my settings and empty the caches for some files.
I have literally done everything to make this stop/give me more room. I have moved all applications to my memory card that is possible, and I have deleted almost all of my caches that are available. (I think the problem is the horrible Myspace and City ID that nobody can remove unless rooted).
Anyway, I was wondering if there is anything that I could do besides start removing apps. It is getting so annoying.
Thanks for the help!
