1. IuseToLoveTechnoligy's Avatar
    On my Samsung Galaxy Tab4, I use a 3rd party keyboard app (Hackers Keyboard). What Id like to know is: Is there an app, a means, or way that I can somehow store certain things I must type repetitivly like my email address, or a password , etc... Dont know if Im saying this right, but I believe that Im looking for something that will allow me to create macros (like my email address, or phone number) and be able to pull up the data ( ie my email addy) by hitting on of the FUNCTION KEYS (F1 - F12) for example. THANK YOU!
    02-06-2018 09:10 PM
  2. Tim1954's Avatar
    Some keyboards have their own clipboard where you can store stuff you use often... SwiftKey has, not sure about yours...
    02-06-2018 09:44 PM
  3. ManiacJoe's Avatar
    I use the SwiftKey keyboard. It learned several of my email addresses so that they became part of the "suggested" words.
    SwiftKey also knows what is on my multi-item clipboard so that when I type the first part of any of that text, the whole previous "copy" is suggested.
    02-07-2018 05:11 AM
  1. Replies: 2
    Last Post: 02-09-2018, 12:18 PM
  2. Replies: 1
    Last Post: 02-07-2018, 11:36 PM
  3. Replies: 1
    Last Post: 02-07-2018, 11:01 AM
  4. LG G5 change the color of the default calender
    By Android Central Question in forum LG G5
    Last Post: 02-06-2018, 01:36 PM
  5. LG G5 change the color of the default calender
