1. djfro05's Avatar
    I have an LG L5 that is 1 1/2 years old and, over the past week, the battery has been quickly losing its charge after a full charge. I was told this was probably due to a new upgrade issue and to do a full factory reset. I did the full reset but the battery still seems to have the same problem of discharging rapidly. Does anyone have any ideas for my next step?
    02-07-2018 07:15 PM
  2. Mooncatt's Avatar
    At that age, I wouldn't be surprised if the battery is simply worn out and needs replacing.
    Do you let it drain to zero? If so, is it now shutting off earlier, like at 10+%
    02-07-2018 08:11 PM
  1. "Camera Unavailable" Issue - Verizon V20
    By Almeuit in forum LG V20
    Last Post: 08-25-2018, 10:48 AM
  2. Replies: 1
    Last Post: 03-26-2018, 08:34 AM
  3. LG G6 When wireless charging screen only shows the always on display
    Last Post: 02-07-2018, 06:40 PM
  4. Lock screen issues, android stereo.
    Last Post: 02-07-2018, 04:37 PM
