1. CoKain-Tremaine's Avatar
    Did anybody who bought the Note FE used Phone Info to check their device to see if it was new or original? It said my phone was original but it was activated on 9-15-2017. I just bough this phone on Feb. 2, 2018........I'm assuming I got a used phone because it was activated 5 month ago. I also went into About Device and checked my Sim status. It also showed that the first called was made on 9-15-2017. When I got the phone, the box was sealed but I noticed there was no plastic on the front or back of the phone and no sticker on the back of the phone either. I caint pay $770 for a used phone!
    02-08-2018 08:28 PM
  2. chanchan05's Avatar
    Yeah, basically the entire Note FE line is all the Note 7's that were produced which had the batteries replaced. This includes the ones that were returned.
    Technically though, Samsung certifies your purchase as good as new and has warranty to cover.
  3. CoKain-Tremaine's Avatar
    02-08-2018 08:47 PM
  4. pkcable's Avatar
    I thought the whole point of the FE was to re-use all those Note 7s that got returned? How could it NOT be a refurb?
    JHStewart1023 likes this.
    02-09-2018 10:30 AM
  5. chanchan05's Avatar
    pkcable likes this.
    02-09-2018 10:38 AM
  6. L0n3N1nja's Avatar
    The entire Note FE line is returned Note 7s with smaller batteries installed.
    The activation around 9/17 seems a bit odd, but I wouldn't worry much about it personally.
    02-09-2018 12:45 PM
  7. jasonandrews25788's Avatar
    Yeah I think it's a note 7 unit with battery replaced.
    02-11-2018 04:24 PM
  8. SpookDroid's Avatar
    As others noted, all FEs are re-purposed Note 7s. Also, the activation/call might be from Samsung's QA team testing? But yeah, if you purchased an FE, you're not getting a freshly-made phone. That's the point of the FE.
    02-13-2018 04:33 PM
  1. New to this
    By Carliss green in forum New to the Forums? Introduce Yourself Here!
    Last Post: 03-23-2018, 10:11 AM
  2. New member
    By JC8865 in forum New to the Forums? Introduce Yourself Here!
    Last Post: 03-23-2018, 10:10 AM
  3. Galaxy Note 5 unlock
    By DireVulf in forum Samsung Galaxy Note 5
    Last Post: 02-08-2018, 06:37 PM
  4. Pin to start option for notes
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 02-08-2018, 05:52 PM
  5. Pin to start option for notes
