1. Mehranab1's Avatar
    Hi , im using asus ZenFone 2 since last year and right after i bought this phone I've been hacked by a hacker who i know. He is in my android system .since then 20 time i did factory reset and updating apps but he disturbes me again he put funny things in my apps or manipulate them even he intentionally opens my apps or opens my dial pad and starts dialing to make me angry..so how can i reinstall android to throw out this bastered annoying hacker out please help me ,,its one year that he is disturbing me , not only me he hacked many other relatives and friends who were in touch with me...pls help
    02-20-2018 04:19 AM
  2. belodion's Avatar
    Have you reported this to the police?
    02-20-2018 05:20 AM
  3. Rukbat's Avatar
    Are you sure it's a hacker and not a virus?
    If you're sure you want to reinstall the system (you don't remove the original one - that turns the phone into a hand-warmer), go to this link on XDA. He explains how to do it, step by step. (Use method 2, so you can choose the system for the right model Zenphone 2.)
    02-20-2018 04:57 PM
  1. Alcatel One Touch Android
    Last Post: 02-20-2018, 02:36 PM
  2. gaaxy tab S2 screen broke, can i transfer to a pc?
    Last Post: 02-20-2018, 02:35 PM
  3. Voicemail app that allows to listen to voicemail while it's being recorded
    Last Post: 02-20-2018, 04:48 AM
  4. How large picture can be printed of better quality if clicked through samsung s8
    Last Post: 02-20-2018, 04:36 AM
