Android versions 4, 5 and 6 seem to have a problem with form data. E.g. if I start to fill out a website form then switch to another app and then go back to back the form it is empty, unlike behaviour in Windows.
Also my place in web page usually goes to back the top on switching apps. Requiring a long scroll down back to where I was reading. Are these paging problem. Any fix such as using a device with more RAM? I would have thought the few gigs most have would be enough. Very annoying.
