1. juraijd12's Avatar
    My phone is still new, 4 months old. Recently, I have observed that when I lock my phone and not use it and put it it my pocket or anywhere, if I check it it would go 79% to 5%, that is just happened within 10mns. It shook me. So I went home and charged it, I also observed that it drained more if I dont use it than using it, however when it reached 4%, it was like it lasted for hour so I wonder what can I do to avoid or heal this ?
    02-26-2018 09:51 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    02-26-2018 03:55 PM
  3. Haile Mecael's Avatar
    Chek obvious first. Is your location, bluetooth and location always on. Go into wifi settings and try to stop it checking wifi all the time in tne advanced settings. Check what rogue programs you have downloaded lately. Dowload CC cleaner and do a clean of your phone. Download a really good virus checker and run a check hour phone.
    02-28-2018 05:55 AM
  1. Totally Disappointed with battery size. Why?
    By Floki_vwo in forum Samsung Galaxy S9 & S9+
    Last Post: 07-01-2018, 11:51 AM
  2. Fast charge not working this morning
    By acfan in forum Essential Phone
    Last Post: 03-05-2018, 02:43 AM
  3. Serious battery issue...please help
    By palanilopez12 in forum Samsung Galaxy S8 & S8+
    Last Post: 03-03-2018, 10:52 PM
  4. Screen using 87% of battery life
    By Android Central Question in forum LG G4
    Last Post: 02-26-2018, 07:57 AM
  5. Screen using 87% of battery life
    Last Post: 02-26-2018, 06:54 AM
