1. Cmylexia's Avatar
    Hello. Not sure if this can be done. I have been using the finger print access on my LG 5 phone. I had to turn the phone off and on as it froze, and now I cannot get past the lock scree without putting in a password. I don't remember the password. Is there a way to bypass the lock screen without resetting the phone? I have a lot of photos on the phone that I do not want to loose.
    03-03-2018 08:09 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Unfortunately, there isn't. The phone should be asking you for the backup password every now and then for additional security, even with the fingerprint sensor working -- e.g., from a cold boot, or if the sensor misreads your fingerprint a couple of times in a row. You've never had to enter the backup password before?
    Google's Find My Device won't work in this situation either, because that only allows you to remotely set a new password if the phone didn't have a screen lock to begin with.
    03-03-2018 08:43 PM
  1. How is everyone's LG V30 Holding up?
    By blessedred in forum LG V30
    Last Post: 03-19-2018, 11:21 AM
  2. Alarm doesn't override end time of DND
    By Ultrasonic2 in forum Android 8.0 Oreo
    Last Post: 03-07-2018, 09:44 AM
  3. Am I running out of storage on Google photos?
    By Lucy Davies in forum Ask a Question
    Last Post: 03-03-2018, 06:59 PM
  4. how do I close the facebook account of someone else that is on my android
    Last Post: 03-03-2018, 04:32 PM
  5. Bell with line through it means what on a couple of my contacts
    Last Post: 03-03-2018, 02:32 PM
