1. ovsraju's Avatar
    Friends,
    I know many people have been facing the phantom/ghost touches issue on moto g4/5 phones. I also went through the same issue for a while. After trying so many ways to fix the issue, finally i found a fix for the issue and thought i can share the same with you, so that it helps you use your phone without any trouble.
    Solution: Go to settings-->display
    Turn off the Adaptive brightness.
    That's it, the issue will be resolved. When you disable it your phone brightness will be too high. Just adjust it to your preferred brightness for your convenience.
    Regards,
    Venkat
    03-05-2018 10:59 PM
  2. B. Diddy's Avatar
    Welcome to Android Central, and thanks for the tip! There can be different causes of phantom touches, so this might not work for everyone -- but it's worth a try!
    03-05-2018 11:32 PM
  1. My Note8 S Pen works without touching the screen
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 10-13-2018, 04:02 PM
  2. Volte problem on moto m after security patch update
    By Android Central Question in forum Moto M
    Last Post: 04-21-2018, 11:56 AM
  3. Touch screen parts aren't sensitive to touch after the last software update
    By xxx JeNeSaisQuoi xxx in forum Samsung Galaxy S8 & S8+
    Last Post: 03-05-2018, 07:35 PM
  4. My Note8 S Pen works without touching the screen
    Last Post: 03-05-2018, 08:36 AM
  5. I do everything but still my moto g4 plus battery draining so quickly,now what?
    Last Post: 03-05-2018, 06:54 AM
