1. nickmyoung1990's Avatar
    Previous posts explain how to turn off unwanted voice and language downloads, however, they do not address the problem of how to locate and remove the space-hogging downloads that are using up the little space I have on my Moto E 2nd gen. Please help.
    03-06-2018 12:50 AM
  2. Rukbat's Avatar
    Settings. Applications. Delete the TTS app, then install it again with just the downloads you want. (If it's Motorola's TTS, you may or may not be able to do that, but look in Applications anyway - removing updates, if that's what the button on the right is labeled, may remove the downloads.)
    03-06-2018 04:27 PM
  1. How to transfer internet autofill from my old phone to new phone
    Last Post: 03-06-2018, 03:46 PM
  2. Can android 7 split, 3circles move to 2nd screen in ,Chrome of tabs.
    Last Post: 03-06-2018, 12:43 AM
  3. How do I know what factory apps I don't need on my galaxy s3
    Last Post: 03-06-2018, 12:35 AM
  4. when edge is active and AOD shut off, the edge screen does not come on
    Last Post: 03-05-2018, 11:32 PM
  5. Replies: 0
    Last Post: 03-05-2018, 10:52 PM
