1. Tigrowski's Avatar
    My grandma uses a cheap 5.1-based Android phone, manufactured by a company named Manta and for the past few days, there have been a problem with turning it on after it randomly shut off (which I described in detail in the previous thread if the specifics are of any importance). Suddenly, I found a way to turn it on yesterday - namely, if you try to turn it on unplugged, you may leave it for a few hours and it won't go past the producer's splash screen. Try to turn it on when plugged in the charger, though - and it'll power up within 30 seconds to the home screen.
    Normally I would think that it's caused by something battery related - but the thing is, it doesn't seem so. First, if you try to turn it on unplugged and leave it on that never ending splash screen, it'll hold its charge alright, not turn off after a minute. And more importantly, second - if you plug it in, turn it on and unplug it - it'll keep working perfectly until you have to turn it off or restart it. What may be the problem, then? Is there anything I may try to do to fix the issue and allow it to turn on when unplugged as well?
    03-14-2018 06:43 AM
  2. pkcable's Avatar
    Sounds like maybe the battery is bad. Is it still under warranty? I THINK I found the support page....
    Customer Support - Manta S.A.
    03-14-2018 09:26 AM
  1. Replies: 98
    Last Post: Today, 02:26 PM
  2. Changing text message background on galaxy s9 plus
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 03-17-2018, 09:48 PM
  3. Download stuck on downloading
    By Un Roux in forum Samsung Galaxy S8 & S8+
    Last Post: 03-15-2018, 12:41 AM
  4. My files won't open on phone. A message pops up and Says cannot be supported
    Last Post: 03-14-2018, 04:56 AM
  5. When will I get my updates?
    By paulwilko10 in forum Samsung Galaxy S9 & S9+
    Last Post: 03-14-2018, 04:34 AM
