1. 7588's Avatar
    I have an Alcatel zip. For some reason the phone screen fades and locks ridiculously fast, like 10 seconds or less. I have completely disabled the screensaver feature, but it has made no difference, it still does it. This phone is only about a month old, bought new.
    Help how can I make it stop, it's so obnoxious!
    03-21-2018 12:04 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Screensaver wouldn't be directly responsible for that. Look for the Display menu in your System Settings, and look for the Screen Timeout/Sleep setting. What's that set to? If it's already set to something longer than 10 seconds, then do you have any power-saving modes or 3rd party battery-saver apps turned on?
    03-25-2018 09:21 PM
  1. Bypassng lock screen from power button?
    By UberPooch in forum Samsung Galaxy S9 & S9+
    Last Post: 08-28-2018, 05:27 PM
  2. Are there any galaxy s9 plus cases that is raised on all 4 sides of the screen?
    By Android Central Question in forum Samsung Galaxy S9 & S9+ Cases & Accessories
    Last Post: 04-08-2018, 03:42 AM
  3. Upper part of screen only working in lockscreen
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 03-18-2018, 04:44 PM
  4. Smart Lock + 60 coordinates = my home address
    Last Post: 03-17-2018, 11:42 AM
  5. Upper part of screen only working in lockscreen
    Last Post: 03-15-2018, 01:30 PM
