1. Bdonaldson8005's Avatar
    How do contacts end up in frequent contacts and favorites list?
    03-21-2018 01:09 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If you mean the Starred/Favorites tab in your Phone app, that shows your Starred contacts first, and then your frequently contacted people afterwards. If you tap menu on that tab, there should be an option to Clear Frequent Contacts (but they'll just be generated again going forward.
    03-25-2018 09:14 PM
  1. How can i change each message notification for each contact on the s9
    Last Post: 03-25-2018, 05:55 PM
  2. Adding a message tone field option to contacts app Samsung S9
    Last Post: 03-22-2018, 03:26 PM
  3. Can I assign a separate text tone for a specific contact on an s9?
    Last Post: 03-22-2018, 11:18 AM
  4. Replies: 1
    Last Post: 03-15-2018, 03:02 PM
  5. Replies: 0
    Last Post: 03-15-2018, 01:59 PM
