1. bmbriefs's Avatar
    Hi folks,
    I have an older minivan with one of those overhead DVD entertainment systems. The system has composite video/audio inputs. I am trying to think of the simplest way to stream video to it from my android phone (Galaxy s8) without living in dongle hell.
    The only way I can think of is to use a USB c to HDMI adapter plugged into a HDMI to RCA adapter, which plugs into my system.
    I'm wondering if anyone else has a creative solution. Has anyone been successful with this type of setup and a chrome cast/roku/fire ?
    Thanks in advance.
    03-22-2018 02:50 PM
  2. SpookDroid's Avatar
    That set up, while possible, requires a very important thing: That your device supports HDMI output through the USB-C port. Not all devices do. (Plus that set up kinda defeats the purpose of no-dongle)
    Chromecast, unfortunately, doesn't support direct connection so you'd need a router in your car to hook them up (or use your phone as a router and cast that way). I believe Rokus are the same. Problem with a Chromecast and most Rokus, is that they are all HDMI. Only the most basic Roku supports composite output (not RCA, IIRC), so you still need the HDMI converter most likely). You can search online for casting dongles that do support WiFi Direct connections (so you don't need a router), but I haven't seen any that support RCA, to be honest.
    03-22-2018 04:39 PM
  1. OK Google to wake phone
    By dov1978 in forum Huawei Mate 10 & Mate 10 Pro
    Last Post: 03-23-2018, 05:30 PM
  2. Replies: 5
    Last Post: 03-22-2018, 05:05 PM
  3. in selfie mode on my s9+ half the screen is black ,how to fix
    Last Post: 03-22-2018, 02:33 PM
  4. AC: ARCore will be available on Galaxy S9/S9+ 'in the coming weeks'.
    By VW Maverick in forum Samsung Galaxy S9 & S9+
    Last Post: 03-22-2018, 02:26 PM
  5. does google home mini connect to icast also
    Last Post: 03-22-2018, 01:42 PM
