G Galane Well-known member May 19, 2011 194 4 0 Visit site May 26, 2011 #1 Does Android support MMF format ringtones?
H homescrub Well-known member Mar 1, 2011 369 66 0 twitter.com May 26, 2011 #2 Probably not. The link is directly from Google, where it shows Androids format supports: Android Supported Media Formats | Android Developers Though of course, if you have a converter, you can switch it to a wav or mp3 file.
