1. TheSarcasticWit's Avatar
    For some reason, whenever I go to silence a ad in an app, or try to select the bottom right letter in Words with Friends, I get this new, weird pop-up menu...
    You can find a picture of it at:
    https://www.dropbox.com/s/pb0q97pcoi42xj9/menu.png?dl=0
    Anyone have any ideas on where it came from and how to get rid of it? It is really messing with my ability to interact with my apps...
    This is an original Droid Turbo, that is no longer on Verizon, so there have been no OS updates recently done (Verizon has not updated the OS since I left either)...
    04-24-2018 10:00 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! That's a common "feature" that other apps will sneak in, often associated with ads. "Phone cleaner" apps like Clean Master are notorious for this kind of annoyance. Do you have anything like that installed?
    04-26-2018 04:40 PM
  3. JanesMom714's Avatar
    I'm having the same problem with my Galaxy Note 4, also some Verizon. I don't have Clean Master or any if the other apps mrntioned either. THIS THINK IS RRREEEAALLLYYY ANNOYING. Is there anything elserious you can suggest to stop it ANNNNOOOYYYIIINNGGG!
    05-27-2018 12:12 PM
  1. How can i get the app off the nottom right corner of My Icons..i have a S8+
    Last Post: 10-06-2018, 01:01 PM
  2. New home page?
    By EmanC19 in forum Samsung Galaxy Note 7
    Last Post: 04-26-2018, 06:03 AM
  3. Deleted an email, now my phone won't let me assign it a new one
    Last Post: 04-23-2018, 10:25 AM
  4. I’m not seeing red dot on messenger when I have new messages
    Last Post: 04-23-2018, 07:34 AM
  5. Brand new SIM card for unlocking?
    Last Post: 04-22-2018, 12:08 PM
