1. Vladko17's Avatar
    Good time of the day!
    I bought a new phone, made a password which is asked after restarting a phone and forgot it. Now I can not boot up the phone and use it. Any suggestions on how to disable this password?
    Thank you.
    04-25-2018 03:52 PM
  2. Javier P's Avatar
    Welcome to the same. Your best option is doing a factory reset from recovery and then enter your Google credentials on restart. The right steps will depend on your specific model. Just remember, if you have also forgotten these credentials you'll end up with a brick on your hands.
    04-25-2018 04:01 PM
  1. How good are Nokia for software updates on their phones?
    By Android Central Question in forum Nokia 7 Plus
    Last Post: 05-25-2018, 08:38 PM
  2. Why am I getting adds on my phone when I'm doing something on my phone
    Last Post: 04-25-2018, 08:08 PM
  3. How to turn off bright light on my zte phone
    Last Post: 04-25-2018, 03:00 PM
  4. I clicked on disabled hangouts...does that mean I have deleted it
    Last Post: 04-25-2018, 02:34 PM
  5. Cardboard apps no longer work on gear vr: please help
    By Chris Topher5 in forum Samsung Galaxy S7 edge
    Last Post: 04-25-2018, 12:23 PM
