1. aroh100876's Avatar
    Hello,
    I have a rooted Moto G5 with Android 7.0 and Xposed Installed. I've had it for a while and I'd never had problem.
    Yesterday, after the Play Store started doing updates, all the apps that were updated, auto-started after the update. Then I found out that the same thing would happened if I installed a new app.
    Some people have suggested that I may have installed an app that is doing this, but besides a couple of games (that I've already uninstalled), I haven't installed anything new in a month.
    I already uninstalled and installed the Google Play Store and Google Play Services updates and I really don't want to do a factory reset.
    Did anybody else have this problem and found out how to solve it?
    Can anybody tell me a way to find which app is launching the apps?
    Can anybody help me in some way?
    Thanks.
    04-25-2018 09:06 PM
  2. Mooncatt's Avatar
    When you say launching apps, do you mean they are opening up for use, or just showing up in your memory usage?
    04-26-2018 06:24 PM
  3. aroh100876's Avatar
    Opening up for use.
    04-26-2018 07:06 PM
  4. Mooncatt's Avatar
    Ok. For that I'm not sure what the issue is.
    04-26-2018 07:22 PM
  1. Replies: 3
    Last Post: 05-07-2018, 08:10 AM
  2. Replies: 1
    Last Post: 04-26-2018, 03:12 PM
  3. Replies: 2
    Last Post: 04-25-2018, 10:20 PM
  4. P20 change app icon shape
    Last Post: 04-25-2018, 10:14 PM
  5. Playing ads on non ad apps
    Last Post: 04-25-2018, 10:05 PM
