How can I install the default android notification panel?
Apr 2, 2017
13
It may look strange but I have a Umi Z and the developers changed the notification panel to black so when I expand the notification bar, everything is black. I don't like that look so is there a way I can change that to the default android notification panel?
This is what I mean with black notification panel:
https://ibb.co/f4sORx
https://ibb.co/enU3Rx
And this is what I want:
https://ibb.co/hHHUzH
I have the official ROM of the Umi Z so if there is a way I can edit the ROM and add the default notification panel, that would be awesome
dooleysdickulove
