1. Maq Attaq's Avatar
    Hi to all,
    I would like to download a 7.22 GB file from MEGA on my Samsung Galaxy S5 Duos,and save that file to the 8 GB MicroSD card!
    Please tell me how do I download and save that file from MEGA to my phone,in a fast way,and without interruptions or restrictions?
    Please help me!
    Thanks to all in advance!
    Best regards!
    05-08-2018 09:46 AM
  2. Rukbat's Avatar
    I'd put the card into a PC and download it to the card, but if you don't have a PC available, you'll just have to download it to internal storage then, after it finishes downloading, copy it, paste it to the SD card and delete it from internal storage. For a file of that size I'd keep my eye on the battery and plug in the charger if it got down around 30% and unplug it if it got over 80% (which are the 2 limits you should always use).
    05-08-2018 12:39 PM
  3. Maq Attaq's Avatar
    Thank you for replying!
    When I try to download the file via my phone from MEGA's desktop site via Chrome,I get this:
    ''Unfortunately,Chrome has an insufficient buffer tо decrypt data in the browser,and we reccomend you to install the MEGA Desktop app to download large files(or use Chrome).''
    How do I fix this and download the file via Chrome?
    Or would you reccommend to me some good internet downloader to download the file from MEGA,and some good VPN in order to download the file without exceeding of the quota from the same IP Adress?
    Please help me!
    05-08-2018 07:26 PM
  4. taino211's Avatar
    Please help me!
    Use the MEGA Android app. That way you get around the Buffer issue.
    05-09-2018 03:31 PM
  1. Facebook location not showing up on my Galaxy S9
    By TravisL839 in forum Android Apps
    Last Post: 06-28-2018, 10:02 AM
  2. Why is my phone sending sounds every 30 seconds for no reason?
    Last Post: 05-08-2018, 11:57 AM
  3. My text icon is not there on my Samsung galaxy S3 mini
    Last Post: 05-08-2018, 08:26 AM
  4. How to Talk to Phone and not Google Home - no camera!
    By Greta Heissenberger in forum Google Nexus 5
    Last Post: 05-08-2018, 08:21 AM
  5. Plus/Pro - Has the keyboard size been a dealbreaker?
    By ctychick in forum Samsung Chromebooks
    Last Post: 05-08-2018, 07:47 AM
