1. Gypsy003's Avatar
    Dear Friends,
    I have a OnePlus3T which I have been using for past over a year. Since 28 April, I am unable to connect to Google services.
    Have already tried -
    clearing cache & data then logging, disabling two way authentication, removing Google account, installing latest Google Play Services from apkmirror.com
    Still unable to connect with the message showing "There was a problem communicating with Google server, try again later"
    Any ideas as to what can be done except a factory reset of the phone which I don't want to do.
    05-08-2018 11:45 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! This happens on both wi-fi and mobile data? What region of the world do you live in?
    05-09-2018 11:08 AM
  3. Gypsy003's Avatar
    Thanks for the quick response...I am located at Dehradun, Uttarakhand, India and yes it's happening on both - Wi-fi & mobile data connection.
    05-09-2018 07:55 PM
  4. B. Diddy's Avatar
    On your wi-fi router, try disabling IPv6. See your router's manual to learn how to access its settings through your computer browser.
    05-10-2018 10:08 AM
  1. Can't see my albums in the Gallery (Neffos C5 Max)
    Last Post: 06-02-2018, 10:05 AM
  2. Car stereo connecting issue
    By Abbi Pritchardjones in forum Huawei P20 & P20 Pro
    Last Post: 05-10-2018, 08:21 AM
  3. Why do I suddenly have a recycle file appear with a number of my photos in it?
    Last Post: 05-09-2018, 01:10 PM
  4. How do you change back to swip password
    Last Post: 05-09-2018, 11:14 AM
  5. Smart cleanup deleted files in my download folder, how do i get them back?
    Last Post: 05-08-2018, 07:21 PM
