1. no_drinks's Avatar
    We've just moved to a house really close to a cell tower, and the speeds on my phone get close to 100mbps. However the WiFi tether caps out at 50.
    I was thinking about using an USB-Ethernet interface but i don't even know what setup I would need for that. Is there a way I can make it any faster? I don't know what protocol i'm even using (b/g/n)
    05-09-2018 04:44 AM
  2. djrakowski's Avatar
    Which phone are you using? It's possible that it's only capable of serving a 50 Mbps connection.
    05-09-2018 12:22 PM
  3. no_drinks's Avatar
    LG Model M1 (Tribute 5), Boost Mobile
    05-09-2018 01:33 PM
  4. djrakowski's Avatar
    According to Qualcomm, the chipset used in the Tribute 5 (Snapdragon 210) should be capable of 150 Mbps WiFi connections, but it doesn't specify whether it's capable of serving WiFi at the same rate.
    How did you measure connection speed?
    It could be a limitation of the device you're connecting to it, too.
    EDIT: here's the Qualcomm page detailing the capabilities of the S210 chipset: https://www.qualcomm.com/products/sn...processors/210
    and the LG page with specs on the Tribute 5: http://www.lg.com/us/cell-phones/lg-...rint-tribute-5
    05-09-2018 01:47 PM
  1. Replies: 1
    Last Post: 05-10-2018, 09:35 AM
  2. Replies: 4
    Last Post: 05-09-2018, 11:02 PM
  3. Why does my instagram keep closing everytime i try to get on
    Last Post: 05-09-2018, 12:03 PM
  4. Replies: 1
    Last Post: 05-09-2018, 03:49 AM
  5. How do I delete pre-programmed events from the calendar
    Last Post: 05-09-2018, 03:46 AM
