1. Kimberlydawn74's Avatar
    I have a Samsung note 3 sm-n900a that is not rooted that I would like to update to android os 7
    05-09-2018 04:09 PM
  2. Mooncatt's Avatar
    The short answer: You can't.
    The long answer: Unrooted devices can only get OS updates via the phone's built in update checker for over the air downloads, or sometimes through a manufacturers website (depending on the phone). There was never an official Android 7 OS put out by Samsung and that phone is too old for them to care at this point. Even if it were available, the hardware may not even be able to support it.
    The only way you would be able to get new updates would be to root the phone and find a new ROM to flash to your device, then get the updates through those developers. That is, of course, assuming such a ROM even exists and is still being developed (and there may not be). If you are able to find something, then you have all the risks of flashing a new ROM and a steep learning curve if you wish to do it yourself.
    05-09-2018 04:36 PM
  1. Sprint Galaxy S8 System Update to Build ...3CRD4
    By NeoTreo in forum Samsung Galaxy S8 & S8+
    Last Post: 05-11-2018, 07:00 AM
  2. Why is apps and games keep pausing on my Android phone
    Last Post: 05-10-2018, 11:22 AM
  3. Error messages in sending texts (SMS)
    By sakaa100 in forum Honor 7X
    Last Post: 05-09-2018, 08:24 PM
  4. Why on my activity log does it say
    By Nickle83 in forum General Help and How To
    Last Post: 05-09-2018, 03:51 PM
  5. I lost one of my apps that just disappeared how do I recover it my Android
    Last Post: 05-09-2018, 03:36 PM
