    I'm trying to send SMS text message (not MMS) through Android messages app, but I am unable to do so. It keeps converting them into MMS.
    The Xiaomi messages app does this fine on my Mi Mix.. Textra messages app does it adequately as well. Strangely Android Messages app keeps converting it into MMS.
    Any help would be greatly helpful.
    I really want to use the stock app on my Keyone and Essential Ph-1 instead of Textra.
    05-14-2018 07:02 AM
  2. Jack1192's Avatar
    05-14-2018 07:07 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! I moved this from the Android Apps forum to the General Help forum, since the former is intended for developers to promote their apps. I also merged your duplicate threads.
    Open your Android Messages app, tap Menu>Settings>Advanced>Group Messaging, and select the "mass text" option.
    05-16-2018 02:11 AM
  1. The settings screen on my Samsung Galaxy Core will not fix. Why?
    Last Post: 05-16-2018, 02:14 AM
  2. Samsung Galaxy s9 - How to change screen display while wireless charging?
    Last Post: 05-14-2018, 04:46 PM
  3. help with downloading text messaging pictures
    Last Post: 05-14-2018, 04:21 PM
  4. How to format my memory
    By Dilli Babu3 in forum Moto E
    Last Post: 05-14-2018, 03:22 PM
  5. My nokia 3 is not merging calls on confrence call.
    Last Post: 05-14-2018, 06:43 AM
