1. nonstopski's Avatar
    I have had consistent Freezing Issues with my Pixel, on and off for about 9 months.
    A reformat always helps for awhile, but the last time I did it, it only helped for a month and a half.
    In safe mode, I haven't replicated the issue, so most would say it's an app that is causing the issue. I previously had a MatLog app downloaded but I couldn't make sense of any of it, even with a guide, and I consider myself pretty tech savvy (I fix software issues on computers and phones on the side for extra $).
    I got the freezing to go away it seemed for a few days but then it came back yesterday.
    Android makes it incredibly hard/pretty impossible to find the one app that is causing the problem.
    Any other suggestions? Reformatting my phone again and starting from scratch for the 5th time just isn't an option anymore.
    05-16-2018 06:39 PM
  1. note 8 and s/d. ard issue
    By mbaverizon in forum Samsung Galaxy Note 8
    Last Post: 05-16-2018, 06:50 PM
  2. Google Chrome Freezes - Le S3
    Last Post: 05-16-2018, 12:14 AM
  3. Android P Beta - Photos Issue
    Last Post: 05-15-2018, 10:39 PM
  4. Replies: 1
    Last Post: 05-15-2018, 02:32 PM
  5. If you join the beta, is there an issue with security updates?
    By PaulQ in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 05-15-2018, 12:38 AM
