1. kolack's Avatar
    Am I limited as to what data can be browsed on the phones internal storage when mounted to my PC? Would a rooted phone allow me browse more into the Android OS and files when mounted as a storage device on my PC?
    05-17-2018 04:10 AM
  2. SpookDroid's Avatar
    Yup, pretty much that's what root does. When your phone doesn't have root access, system files and OS-hidden files aren't available to browse or modify. Root allows this, but it comes, of course, with the risk of potentially bricking your device should you delete/modify something you shouldn't have.
    05-17-2018 12:19 PM
  1. how to remove "Hidden Contents" from lock screen ??!!
    By EymenAkbayir in forum Legacy Android & Other OS's
    Last Post: 09-06-2018, 09:38 PM
  2. Gif Bar has no search bar to look for gifs, how do I get it to appear?
    Last Post: 08-31-2018, 12:20 PM
  3. Replies: 1
    Last Post: 05-17-2018, 01:28 PM
  4. Replies: 7
    Last Post: 05-17-2018, 01:22 PM
  5. My phone can't sign in to Hangout
    Last Post: 05-17-2018, 09:00 AM
