1. carl alexander's Avatar
    I am re-posting this in another attempt to find a solution.
    Phone: Samsung Galaxy S7
    OS Android 7.0
    I have accidently installed a Gallery photo as a wallpaper. Previously I just used the default which was just blank with icons. I want to un-install it and return to my previous setting, Default.
    I have Googled this and all I have seen simply state; Settings, Wallpapers and then change it but this does not work.
    When I go to Settings, Wallpapers and Themes only the screen for Add Samsung Themes to your Home and Apps screens pops up. A check box is selected by default, leaving it selected or un-selecting makes no difference. The bottom of the screen has Start>, When this is started there is a delay of several seconds and a popup of Themes has stopped and a restart app button. Restarting does nothing.
    Settings, Applications, Samsung Themes Disable does not operate (a system file, I am sure) Force Stop works but does not accomplish anything.
    If I go to the Home screen and Long Press a blank space I get the Wallpapers, Widgets, and Screen Grid. The first Wallpaper is the Briefing Wallpaper (that I changed when I got the phone), the other selections are bland with the last one having the + sign to add one. Selecting any of these screens does not change the wallpaper.
    I have deleted the photo from the Gallery but this has not affected the Home screen. I have not checked The Cloud to delete any backup.
    Or is this something that needs to be addressed on the Samsung forums?
    Thanks, Carl.
    05-17-2018 12:17 PM
  2. Rukbat's Avatar
    Try Wallpaper Wizardrii. I was changing the wallpaper every month on a Samsung with that, until I got tired of changing wallpapers. (You can't "uninstall" a wallpaper - some wallpaper has to be there. But you can install any picture, including a picture of a solid color.)
    05-17-2018 12:42 PM
  1. how to force speakerphone on all calls ?
    Last Post: 10-23-2018, 07:14 PM
  2. moto g 3rd gen going to voice mail
    Last Post: 05-17-2018, 01:53 PM
  3. I have a blue. On the left hand corner of my S7
    Last Post: 05-17-2018, 11:08 AM
  4. Samsung Gear S 2018
    By bhappy11 in forum Samsung Gear S
    Last Post: 05-17-2018, 10:54 AM
