1. tujko's Avatar
    hi!
    I am using Samsung note 5 every thing is cool. some time i even play games on it but it does not cause any heat problem in it. But when i turn on Internet or connect to wi-fi it starts showing the sign of overheating. 11 Ways To Prevent Computer Overheating - CPUtemperThen it also gets slower even my skin feels the burn?
    What is wrong with it? can i prevent this android heat issue?
    Thanks;
    05-18-2018 02:28 AM
  2. Rukbat's Avatar
    It sounds as if your wifi transceiver has a hardware problem. the phone has to go into a repair shop (and they'll probably tell you it needs a new motherboard - which doesn't pay, since you can probably buy a used Note 5 for less). If you're very lucky, it's just a loose antenna connection and they'll fix it.
    tujko likes this.
    05-18-2018 12:24 PM
  1. How can I disconnect bt music on my smartwatch?
    Last Post: 05-18-2018, 06:39 PM
  2. My phones data turns off and hot spot turns on frequently can you help me
    Last Post: 05-18-2018, 04:45 PM
  3. My new Huawei P20 pro is stuck on the setup even tho its setup
    By Android Central Question in forum Huawei P20 & P20 Pro
    Last Post: 05-18-2018, 01:14 AM
  4. What apps should have usage access on lgv30
    Last Post: 05-17-2018, 10:54 PM
  5. Whats taking that much space from my Moto X 2nd gen internal storage?
    Last Post: 05-17-2018, 10:07 PM
