1. AndroidFan128's Avatar
    My phone is MiA1. I'm using Samsung earphones. Is it okay to leave it plugged in the jack? Thank you.
    05-19-2018 09:27 AM
  2. N4Newbie's Avatar
    I don't see why not.
    However, you are likely to miss incoming telephone calls and other notifications if the earphones are not actually in/on your ears at all times.
    AndroidFan128 likes this.
    05-19-2018 11:06 AM
  3. Rukbat's Avatar
    And it you somehow lean on the plug, you could break it off inside the jack (or even break the jack). There's no technical reason you shouldn't leave them plugged in, though. As long as the battery is still charged, the phone will work with or without earphones. You'd have to leave them in for about a lifetime before they'd get cold-welded to the jack. (And since you'd be dead, you wouldn't care.)
    05-19-2018 04:30 PM
  4. AndroidFan128's Avatar
    Is this true even when I'm not using my phone for hours? @N4Newbie @Rukbat
    05-19-2018 11:49 PM
  5. ManiacJoe's Avatar
    The phone does not care if the headphones are plugged in or not. The only difference it makes is where any sound goes: speaker vs headphones.
    05-20-2018 01:10 AM
  6. N4Newbie's Avatar
    Yes, but like I said before, how will you know if you receive an incoming call or other notification?
    05-20-2018 07:56 AM
  1. How to unhide my applock in vivo y21l?
    Last Post: 05-21-2018, 11:18 AM
  2. Sharing My Experience With The Nokia 7 Plus
    By Alex_Hong in forum Nokia 7 Plus
    Last Post: 05-20-2018, 09:20 PM
  3. Where is the reciever on my phone ?
    Last Post: 05-19-2018, 04:31 PM
  4. I lost my text widget
    Last Post: 05-19-2018, 03:54 PM
  5. Tone option ( Standard, Vivid e.t.c.. ) in PRO shooting mode is only for photos?
    Last Post: 05-19-2018, 09:03 AM
