1. Whitney Victorine's Avatar
    How do u disable the frp lock once you have initially done the bypass?
    05-22-2018 08:19 PM
  2. Mooncatt's Avatar
    You don't. And while it may be *technically* possible, it's not something allowed to be discussed on these forums.
    Laura Knotek likes this.
    05-22-2018 09:32 PM
  3. Laura Knotek's Avatar
    Discussion of bypassing factory reset protection is not permitted here at Android Central. Thread closed.
    05-23-2018 02:12 AM
  1. How do u bypass the frp lock on samsung galaxy j3 prime?
    Last Post: 05-22-2018, 09:42 PM
  2. Samsung S6 stuck on optimizing apps when restarted
    Last Post: 05-22-2018, 04:12 PM
  3. Replies: 1
    Last Post: 05-22-2018, 11:38 AM
  4. Samsung Galaxy J3 Pro 2017: How to get the microphone on keyboard
    By jabbababba28 in forum General Help and How To
    Last Post: 05-22-2018, 07:22 AM
